lighter wheels and tires
I want to get sum skinnies in the front and a taller tire on the rear with all 4 lighter rims. What size rim and tires would be best? These well mainly be my drag strip rubbers. And where can i find some?
2k... be sure to consider the effect on your ABS braking system. If you go past 1" or so differential, the light on the dash tends to bark at you and can trigger them to activate too soon.
.... as you were
.... as you were
Because of your power levels. The majority of the people that I've seen running a 28" tire on our cars typically have a sub 12 second car or better. I'm currently figuring out a setup for myself. I'll be going with a 275/50r15 in the rear on a 15x8 inch Summit Star rim.
I agree, stick with a 26" tire on an 15x8" rim. You can pick up a set of Greg Weld wheels that look pretty much like regular welds for really cheap. Greg Weld died recently. I'm not sure what is going on with his company, but his wheels are extremely cheap right now.
Since you don't have a built rear, I would suggest not going with a slick. MT ET Street Radials come in 275/50-15s and will be plenty sticky with that large sidewall and soft rubber compound.
