whats your mpg
#22
The last time i measured it i got 22-23 with a 50/50 mix of city and highway, and 26 highway only. That was driving it fairly easy too.
Ever since i got my bigger injectors, and custom dyno tune, my mileage has dropped a tad. I haven't measured it since then, but i can tell that i'm not getting quite as far on a tank of gas...everything else being equal.
#25
maybe your thermostat is stuck open, your engine not getting up to normal operating temperature and running cold isn't helping.
#26
since you said you use to run rich, maybe you damaged one of your front 02. At least with a wideband, consistent exposure to <14 AFR shortens the life by quiet a bit. Id check the plugs and the O2, what AFR are you running?
#28
#29
