03-04 supercharger on aviator engine 4.6 32v ?????????????
hello again i got the aviator engine already eaton m112 supercharger out of 03 cobra would fit on my lincoln aviator 4.6 32v engine ?
what do i need to complete this project ? thank you
This plus misc. hoses, gaskets, hardware, pigtails,MAF, oil cooler, amongst other things. Good luck.
• Supercharger with stock pulley
• Lower intake
• Intercooler
• Water manifold with nipples
• Throttle body with plenum
• 39 lb. injectors
• Vacuum actuator w/attaching hardware
• EGR valve – new straight plug IAC – w/attaching hardware
• EGR sensor bracket
• EGR riser tube
• Accelerator cable with bracket and attaching hardware
• MAF housing
• IAT 2 / BARO sensor w/ attaching hardware
• Timing chain cover - new
• Cross tube w/sender
• Main pulley bridge w/tensioner and idlers
• Alternator idler bracket
• Used alternator
• Both alternator to block bracket
• Harmonic balancer
• Lower caged charger pulley with idler
• Intercooler pump with bracket
• Intercooler reservoir
• Heat exchanger lines
• Hard intercooler line at block
• Heat exchanger brackets
• Heat exchanger
• Long heat exchanger lines
• Heat exchanger engine hard lines and hoses
• P/S bracket
• Belt engine cover
• Air intake to MAF housing
• Long upper cross tube hose
• Upper radiator hose
• Blower belt
• Accessory belt
• Lower intake
• Intercooler
• 39 lb. injectors
• EGR riser tube
• MAF housing
• Used alternator
• Harmonic balancer
• Heat exchanger
• P/S bracket
• Belt engine cover
• Blower belt
• Accessory belt
Galactic
04-29-2019 02:56 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-03-2015 07:14 PM
