Ford Parts Distributor?
Why would you want to pay Stealership prices even if it is 10% above it is still more than aftermarket parts. The stlealership is the absolute last resort stop for me when shopping for parts
Latemodel resto has plenty of OEM parts if you want OEM at good prices
Also check www.rockauto.com. I just bought my window regulator from them for $15 cheaper than latemodelrestoration and also saved on shipping. Both places had the part oem, btw.
Thanks for the useful replies guys. The main thing is I'm trying to piece together the 8-rib pulley kit off of the F-150's and I have yet to find a site to sell the kit.
BraMas - LMR does have a lot of good OEM parts and wouldn't have posted on here if I would have found it on another online store's site.
I'd like to piece to together separate rather than getting a kit anyways since I might invest in an SFI balancer.
Lot's of folks ask about it and GI Joe is the only place I know of
It would be great to do it for 250.00
I've found this on a few other forums: It appears however that it may not be entirely accurate.. I can update the part number list for the 01-04 timing cover guys as I get it done here in the next month or so.
8-rib Pulley upgrade parts list “Vehicle 5.4L F-150”
Item (Ford motorcraft P/N)
A/C PULLEY 7UZ-19D784-AA(YB-542)
Alternator pulley F65Z-10344-AA (GP-720)
Power steering pulley XL3Z-3A733-AA
Tensioner 1L3Z-6B209-AA
Crank pulley XL1Z-6312-CA
Idler pulley F65Z-8678-AAA (YS-250)
Water pump pulley F6TZ-8509-AA
4.6L 8-Rib Conversion Pulleys
Name Ford Part Number Cost
Alternator pulley GP-720 $20.84
Power steering pulley XL3Z-3A733-AA $16.63
A/C Clutch pulley YB-522 $71.48
Tensioner 1L3Z-6B209-AA $42.30
Crank pulley XL3Z-6312-CA $60.82
Idler pulley YS-250 $19.66
Water pump pulley F6TZ-8509-AA $18.05
Total $249.78
4.6L 4v Mach 1 8-Rib Conversion Pulleys
Alternator pulley F65Z-10344-AA $23.02
Power steering pulley 2L3Z-3A733-AB $36.25
A/C Clutch pulley F7UZ-19D784-AA $57.52
Tensioner/Idler pulley 1L3Z-6B209-AA $56.23 (2)
Crank pulley XL1Z-6312-DA $86.12
Grooved Idler pulley F75Z6B209-EA $56.23
*Water pump pulley F6TZ-8509-AA $20.22
Total $396.86
*You will need to use a long snout Water Pump from a Pre-2000 4v or shim the pulley 22mm.
Total $249.78
Total $396.86
