so I got the 42lb injectors, bracket assembly, discharge assembly, intake assembly, oil drain, and oil feed ordered. the place im getting the SVT pump from is out of stock so I'll order that on Monday when they get more. And boost gauge and pod I'll get soon along with the other odds and ends. woot!
So, the stock 3.6 pulley makes like 8lbs. of boost correct? With those cams. i'll be interested to see your dyno numbers. Regardless, it should run strong.
