What is the best N/A stage 2 cam?
Yea i did a BUNCH of research before i bought mine. I went with the hitechs, i gained 30 hp, and they sound sick! Made my car so powerful i cracked my intake haha. Now the edelbrock is on the way!.
But good luck with your decision i think you'll be happy either way.
First I would say the comp cams are not bad, good enough in fact that trickflow feels pretty confident using them testing the new heads, I believe. Second, from most of what I've read, the performance from most stage 2 cams are pretty close. You'll do pretty well with just about any one of them as far as I'm concerned. Some say you don't need springs, I would ignore that. I'd look into things like if notching the pistons is going to be necessary or not.
I believe that valve springs should always be done while youre in there messing with stuff anyways. And not all stage 2 cams perform the same. They may have close to the same peaks but its the midrange where they are separated. And mustangmancp, i thought HOSS did all the footwork and you just benefitted from it just messin with ya man. And yea mrtstang, i think im going to look into getting Nick's stage 3 cams with his cam gear degreeing service and then get some new valves through him as well and then installing them myself with some help from my mechanic friend at his garage. I'd like to say that i'll have cams this summer, but who knows. I just found out this week that i'm going to mustang week so the pressure is on to have an awesome performing/looking car for the 3rd week of july. Looking at getting a second job for over the summer to do as much as i can before.
I'll add CMS Stage II's in the mix. If you look at any "Best E.T." list most of the fastest cars use these cams.
There are others scattered through the list but CMS Stage II's lead the pack. They won't always win on the dyno but if you're looking for track performance like I was it's a easy decision. Also the 190rwhp gained from a 150 shot on my car is something to think about down the road if you ever want to step it up.
