lets talk clutches
look into XTD clutch on ebay - i have 2.5 clutch it feels great and the clamping power is awesome. These clutches are made with finest quality for performance and longevity.
Whatever you don't over build your clutch for your car as you weak point will be the tranny.
This is stage III details below. I have 2.5 with Kevlar Disc.
XTD 6 puck "MIBA" Copper Ceramic clutch is designed for the serious enthusiast with just Stock to considerable modifications.("Miba" Copper Ceramic Material is well known for AirCraft brake material.It is more Durble and hold 60% more Torque capacity than Cabontic or Kevlar Material also "MIBA" Disc grips 30% harder than Cabontic Disc) This disc features 12 high-coefficient ceramic pads for quick engagement and the extreme duty friction needed. Our specifically designed high torque disc delivers maximum holding capacity without compromise. The sprung retainer assembly boasts 6 dual springs and 6 severe duty retainer rivets, ensuring power and reliability. This XTD Stage 3 clutch kit fits 2/01 - 2004 Ford Mustang GT with 4.6L V8 (T3650 trans) / 1999 - 2001 Ford Mustang Cobra with 4.6L V8 DOHC / 2003 - 2004 Ford Mustang Cobra with 4.6L V8 Supercharged .This XTD Stage 3 Clutch Kit Includes XTD High Clamp Racing Pressure plate (3000ft/lbs Clamp Loads),XTD Racing 6 Puck Copper Ceramic Disc,Racing Throw out Bearing,Pilot Bearing and Alignment Tool.This XTD Pressure plate Holds 35% more HP and Torque Compare to Stock Cobra Pressure Plate and This Pressure plate is made from ductile iron and heat Treated Which is about 30 to 40% Stronger Than Just Stock Cast Iron Pressure plate. XTD Stage 3 "MIBA" Copper Ceramic Disc is designed for Ultra Racing Purpose and it Graps Much Harder Than Carbontic or Kevlar Disc also It will Increased Acceleration.However,It designed also Smooth Engagement and improved durability for Street so It won't make you difficulty on Daily Driving.This XTD Stage 3 clutch kit is Suitable for Just Stock or Highly Modified Ford Mustang.All XTD Racing Clutch kit Requied 500Miles Break-in Period.
If you need more info about product or company click " PAGE"
Perfect for Street and proofed on Track!!
Pressure Increase 25%/Torque Capacity 487 ft/lbs/ 550HP Capacity.
Professional installation recommended.Just buy parts from us and give to your Mechanic for Install.
12 months or 12,000 miles manufacturer defect warranty
XTD STAGE 3 RACING CLUTCH KIT INCLUDES
XTD HEAVY-DUTY RACING PRESSURE PLATE (3000 Ft/Lbs Clamp Loads)
XTD 6 PUCK COPPER CERAMIC RACING DISC
RACING THROW OUT BEARING
PILOT BEARING
ALIGNMENT TOOL
XTD CLUTCH INSTALLATION GUIDE
XTD LOGO WINDOW DECAL
PILOT BEARING
ALIGNMENT TOOL
breaking
10-02-2015 01:27 PM
junior04
09-28-2015 10:53 AM
