I have an 98 mustang with all the bolt ons, pi head swap and stage two cam. My last pull was 305rwhp 320 rwtq at SGS. Now I just put on the EB intake manifold, fuel rails, 42lb injectors, 90mm mass and 100 shot wet (NOS). Im going to SGS tomorrow at 9am to see what see pulls. I was just seeing if you guys would know what kinda of numbers to look for?
im gonna call 410rwhp and close to 470+rwtq. BTW, where at in PA are you??? Im right around harrisburg for school right now.
Im in Mechanicsburg 5 mins from Harrisburg. Are you going to HACC or Penn state Harrisburg? I go down to Handover a good bit on friday and Saturday nights.
I Have a bullet stage two N/A cam Dur int 225 exh 235 lift int. 562 exh. 576 I Got it from VT racing. I dont know if they are still in busness tho. I also have upgreaded vavle springs, stock pi head, trick flow upper plumm, bbk 75mm TB, k&n intake, steeda UDP, 255 fuel pump, BBK long tubes, H pipes no cats, mac mufflers, 373 gears moser 31spline detroit truetrac, UPR solid upper and lower adjustable contol arms, Al drive shaft. With this setup I was running 8.2 at the local 8th mile all day with a set of et steets. I havnt been to the track to much . Im hoping the EB Intake, fuel rails, injectors, mass air and 100 shot wakes this car up!! I have seen cars with 100 shot with close hp number N/A hit any where from 425-450hp and 475-525tq
