gear whine
Old 03-12-2010, 01:01 PM
erniej99
erniej99's Avatar
Default gear whine
i just installed 373s in my 99 mustang gt i did it by myself with help from a teacher at school i replaced the bearings, and everything seemed to go perfect replaced everything the same way it came out..it drives good no clunking or anything but if i listen close with the radio off i hear a slight whine when decelerating and mostly when im in 2nd gear iv only put about 60 miles on it since the install..iv heard the break in period is about 300 miles should i wait till then to see if it goes away..little things like this drive me crazy so what can i do to get the whine to go awayyy all feedback is appreciated thanks
erniej99 is offline
Old 03-12-2010, 01:20 PM
Moonshine
Moonshine's Avatar
I hear my gears whine sometimes. No big deal. Aftermarket gears tend to do that sometimes.
Moonshine is offline
Old 03-12-2010, 01:28 PM
hot wheels
hot wheels's Avatar
there shouldn't have any gear whine.. did you mix in a bottle of friction modifier in when you filled the rearend back up?
hot wheels is offline
Old 03-12-2010, 01:53 PM
erniej99
erniej99's Avatar
no i used royal purple i heard that was already in it..should i add some anyway
erniej99 is offline
Old 03-12-2010, 02:03 PM
Fizzics Boy
Fizzics Boy's Avatar
Not unless the clutches in the trac-lok are binding. You will know if they are too. It'll chatter going around turns and all.
Fizzics Boy is offline
Old 03-12-2010, 02:07 PM
erniej99
erniej99's Avatar
so shud i drive leave it the way it is i mean its a slight whine but i dont want it to get worse over time
erniej99 is offline
Old 03-12-2010, 02:10 PM
Fizzics Boy
Just drive it. No john force burnout or pulls for the first few hundred miles. And my gears made some noise when i first put em in and now they're quiet. Unless its really loud and noticeable even with the radio turned up you don't have anything to worry about. BTW, what brand gear did you go with?
Old 03-12-2010, 02:16 PM
erniej99
erniej99's Avatar
ford racing
erniej99 is offline
Old 03-12-2010, 02:22 PM
Fizzics Boy
Ford Racing is the best one and the one you can install with the least amount of noise. Motive tend to be nosier as they are harder to get set up perfectly, but it is all about the install like said above. If the pattern is on and everything is to spec and there is still noise it has to do with the way the gears were machined, and then at that point the noise would be inevitable.
Old 03-12-2010, 02:25 PM
erniej99
erniej99's Avatar
so u dont think its because there new and the whine will go away as they get broken in
erniej99 is offline
Quick Reply: gear whine
