kool!!! coming together nicely. if you are getting a KB next summer i dont know what to tell you about gears. I have 410s with my procharger and 1st and 2nd is an absolute riot. And i mean it, no traction AT ALL... im going to be changing my set up later (d1 upgrade, fuel system, and prorbably going down to 373's)
Should i be looking at somehting other than 3.73's then??
LOL you crack me up. Right now you should be reading up on how-to's on installing shocks/struts/springs... Not thinking ahead about what you are going to do next lol. Take a break. Your brain will thank you!
HP - I'm not worried or over thinking! Simple a question to the above guys. I have been going through different spring and such install instruction sheets though, haha! And my kit will have its own instructions, so I'll be ready!!
The only time that i think i'd want 3.55's or higher would be if i was going turbo. 3.73's are probably all the lower that i'd go unless ive got a 700+rwhp cobra then i'd let the stock gears in there. Turbo's are the only power adder i think that you should go that high in. 3.73's with a KB FTW!!! I mean if youre going to do gears, at least make sure you'll be able to tell you did it afterwards. 3.27-3.55 isnt that big of a jump and i dont think it will make much difference.
