90k miles what can i do for hp?
I have a 01' mustang gt and I want to get more hp out of it. My only problem is the motor has just under 90k. The motor runs very strong and has always been taken care of. I would like a supercharger but afraid that might do to much wear and tear. Thought about a chip but I want other opinions as what would be best. The car will soon be making 8 hour trips from my duty station to home so keep that in mind. Thanks for all the help. John
theres a guy on here that has 135k miles with a procharger running 9lbs of boost. he's had it on there for a longgg time too. i say go vortech or procharger, get it intercooled and have fun. boost wont start unill like 3000 so it will be like stock under 3000rpms
I would love the pro charger kit. It has everything with it, like this:
http://www.superchargers4less.com/pr...1fe212-sci.htm
^ agreed, my 99 has 11psi and 84k, although it cracked 3 pistons, that was from too much boost and bad tune.
Stay around 8psi non intercooled, or around 11 intercooled and make sure you do the fuel system(injectors/pump) along with maf and a good tune you should be fine!
Whatever you do make sure you have a good tune. On stockish power your car can handle a little detonation. But the ring lands on the stock pistons can crack the first time you get a bad knock on boost or nitrous.
It's better to have a car that has a tune on the safer side than trying to squeak every last hp out of a tune and being right on the edge of blowing your motor.
