Cutting springs
that was the down side of cutting mine when I did. A little while later I had to lift the car again and do it all over. Doing it right the first time is always the way to go but I was bored one day and said F it why not
Please explain to me how cutting the fronts is any different from the rears. They are both a linear rated springs. As long as you dont cut off to much it will work just fine.
Probably because of the difference in dampening from shock style dampers to strut style dampers. They dampen differently i'd say or they wouldnt be called different things. But i might just not know what im talking about. lol
well, i fear that I would bottom out, because i have 20x9 in the front 20x10 in the back.
Funny story really quick: When I first bought my mustang, it already had Jade-R wheels (20x9 and 20x10). I realized that i was having rubbing issues, but only when i turned left... as it turns out, the idiot that had previously owned the car, decided that he wanted to rotate the tires, so i had a 20x9 and a 20x10 in the front.... pft, idiots theses days.
it makes no difference if you cut off a half a coil to a coil. its a linear rate spring. I would never do it because its a ghetto way to mod your car.. but it can be done without any issue.
http://mustangboards.com/mustang-cla...eadlights.html
Dude their is no way I would cut springs. Spend $150 or take the time 2 mess up ur springs by cuttin them and then spend the $ 2 fix it.
I just cut mine 2 weeks ago and I like it. I cut 1 coil off each spring and it lowered it 1" all the way around. Would I do I again, Hell yeah. I've had a few lowered vehicles that where "lowered right" and every one had a stiff ride. My silverado was the worst, there was absolutly no weight transfer so I couldn't launch very well.
I decided to cut my springs and replace the front struts with the cheep monroes for a 92 GT because they are 1" shorter then my stock ones. The car seems to ride about the same as before. I haven't had a chance to really push it through corners or try any hard launches but it rides very nice on the highway.
