Control Arms and Sway Bar
What do you guys think of this combo for upper and lower control arms and rear sway bar?
BMR upper and lower control arms
Eibach Rear sway bar
http://www.lethalperformance.com/sus...shings-p-22734 upper
http://www.lethalperformance.com/sus...shings-p-22731 lower
http://www.lethalperformance.com/99-...ll-bar-p-30660
uppers non adjustable with spherical
lowers non adjustable with poly
all info on control arms is appreciated, why wait on the sway bar?
ill have the arms done and springs are already done, only left to do would be struts and subframe connector
You will want spherical bushings on your LCAs. If not you aren't gaining anything from buying them.
Your sway bar, from what I am told, is something you buy last because it is a what you use to fine tune your suspension setup.
spherical adjustable upper control arms
spherical non adjustable lower control arms
what about the steeda upper and lower control arms? are they a good value or just plain overpriced?
http://www.americanmuscle.com/stallorecoar.html
