Coilovers
Coilovers
Is there any shot that you would be able to use tokico HP struts with a coilover kit such as UPR or is it not recommended?
What are a list of struts that you "should" use with coil-overs?
I am trying to cheap out here and use my tokico HP's (blues) and a coil over kit but idk if its going to work. I just want to drop my pony and have the adjustability as well as comfort/handling abilities without breaking the bank.
If i could use my HP's, ill order the coil over kit now and drop it down to where i want it...
Yeah i have heard that with a lot of struts you need to grind a part down on the top of the strut or something
Contact Maximum Motorsports. Thats the only coilover kit i'd buy besides Griggs and you'll HAVE to get caster/camber plates. You'll probably have to use some kinda weak spring rates which will still give you the same/better performance than stock location springs and the ride is going to be awesome. MM makes coilovers to use tokico struts so talk to them.
MM doesn't recommend coil-overs for those Tokico's. The Illumina or D-Spec's will work. You will only be able to run a front coil-over with Tokico's. MM won't make a rear kit because of the way the Tokico shocks are made.
These struts probably really aren't meant for the heavy loads the CO's will put on them... I just want the coil overs for the increased handling and the adjustability...
What is a nice CO set up for up front w/o breaking the bank? and which struts are best?
Youre gonna break the bank for a good coilover setup. Its going to cost you a minimum of $900 in parts to get a good setup. MM coilover kit, Koni yellows(on sale through the koni website for 25% off), and MM c/c plates. the CO kit is $370, the struts are $312, and the c/c plates are $200. So you add that up to about $882 in parts and i dont know what the shipping is going to be so you're looking at $900+ for a good front coilover setup. The rear will be cheaper as you dont need C/C plates and shocks are generally cheaper than struts are. Shocks are at $216 and the coilovers are $450 so you'd be looking at around $680+ after shipping and all that stuff. But that would be the route i'd be taking(that was the route i was going to take...til i found out im getting an IRS!!! ) I still will be going that route but with the IRS stuff.
+1... Would i be able to?
You aren't going to get away with a cheap coil-over set up unless you are drag racing. The MM and Grigg's stuff isn't cheap.
