Sniper/ delta force tunning help
If any of you guys that have the sniper software could help me out it would be appriciated. I am in the process os returning my gt to stock so I can sell it, one thing I need to do is to unmarry the tuner from the car. I am not sure how to do this since I lost my instruction manual for it, so if any of you could help me out.
Thanks.
Thanks.
If the original tune is in position 6 on the interface (it should be if you have only used the interface on once car--use Multiloader to check), then just flash position 6 to the PCM in the same manner you would any tune.
If it's not in position 6 then use Multiloader to load it to position 1 and flash it from there. Note that it must be the original stock tune that you downloaded when you first used the system.
Bullets are stored in the interface, and the VIN of the original tune must match than of the tune installed on the car or you cannot unmarry the interface.
JDWalton
09-24-2015 08:47 PM
ccdguy
09-19-2015 05:20 PM
