Brake questions.
Brake questions.
My brakes are making a pretty consistent squealing noise anytime I apply a decent amount of pressure. Do you guys think I could get away with just doing pads or would you have someone check out the rotors too. I want to keep it as cheap as possible. Pads should be pretty simple to install right? Any good suggestions for a good, cheap pad would be great as well. Thanks as always.
It's definitely a squeak. I think I will be good for another 5k or so but I just want to budget my needed repairs. When we pulled my rotors off to do the springs, my mechanic buddy said they looked fine. I have no idea what to look like but I know that when the squeling starts, replacement time is right around the corner. They are stock rotors and pads. Car has 59k on it.
Well whenever you go to chane your pads, give your rotors a good inspection, run your hand along each side and if they are still smooth you are ok, but if they feel like they are grooved or worn, might as well change them as well
Hawk HPS' are a great minimal dust pad. They stop wonderfully and don't make any noise. I speak from experience since I have these. As stated just yank your wheels and inspect the rotors, if it's just a squeak, pads should do the trick.
I actually had a Ford Master Tech look at it today real quick and he said I have about 5-10k left. Also said might as well turn the rotors while I am at it. I would love to do the Cobra upgrade kit or something better but I just don't have the money.
Matt's 95 Stang
10-05-2015 07:16 AM
treesloth
09-28-2015 07:03 AM
09-25-2015 06:42 PM
