Used gear advice needed
I am pretty sure that you should be able to see wear marks in the middle of each tooth...
I had the option of getting used 3.73's and decided against it... I heard that they are harder to set up without whining or that you must install them exactly to what they were installed in the previous car to prevent whining..
Idk.. I avoided the whole hasssle and bought brand new for a couple bucks more...
I was thinking that as long as the gears were in good shape, they wouldn't be any different to install than if they were new.
yeah, I have never dealt with used gears so I didn't know if stuff like that would be an issue. Lmao @ a couple bucks more!! More like 120 bucks more
Used gears are tough, because even if they look like they are indecent shape you could install them and have problems. You would have to have a differential shop, machine shop, or whatever take a good look at them for you to make sure there is no unusual wear. IMO it's not worth it to save roughly $100
Don't let us steer you away. Many people have installed used gears and they have no problems.. Me on the other hand, i like to take risks sometimes, but i couldn't afford the shop having to go into the rear again bc of a whining noise or something along those lines... I ended up spending like $50 more for a brand new FRPP set and mine are installed with zero problems.. For something like gears, i would rather it just be done right so that it was only done once... Just like i would be reluctant to buy a used rear end...
If it were something as simple as a cai, or tb, then I'd take the risk. I just don't want to go through tearing it apart a second time, if they don't work right.
Thanks alot for all the oppinions.
I got my gear used out of an explorer. It is perfectly fine and has never whined. I have had a few friends by brand new gears that whined. OEM is the way to go if you don't want it to sound like a dying cat under your car. you can find oem 4.10 gears I believe they are in the 4x4 broncos
I'f you buy good gears they should not whine at all. I, at least, know that.
HP...
Yeah, I got them ordered today. I just went with the Ford Racing 4.10's from AM.
