stage 2 cams you should be hitting 300rwhp tho i thought? unless your on an auto. from what ive seen stage 1 cams will hit around 290-295 on a full bolton PI gt, and stage 2's will hit right around 300.
thats with a dyno tune also.
It depends on the dyno. He's only at 246 rwhp. Going back to the same dyno (which would be the only fair way to compare) he'll be lucky if he gets 30 rwhp with those cams alone.
Now if he get's a good custom dyno tune that could possibly add to the numbers too, but 30 hp from those cams alone will be generous IMO.
No way is he getting 300 rwhp on that same dyno. Not even close.
yea only the 93 octane tune thats it he tweaked the rev limiter my shift points and thats about it not much he could do on the predator i will have a custom tune done when i finish witht the install tho
I have no knowledge of how good the Predator preset tunes are, however you should be doing a bunch better than that--I turned 262/305 on a Dynojet with a UPR catted X, Magnaflow catback, Pro-Prods 70mm TB and upper plenum, and a highly tweaked Delta Force tune of my own doing.
Looks like he's running an auto Cliff, his numbers sound about right if that's the case.
Back to the topic, you're not going to hit 300RWHP with the cams alone.
If it's a 5-speed and your tuner told you he "tweaked your shift points", then yes, I would try a different place...
lmao i agree i thought for sure it was auto when you said that.. cams aren't going to put you at 300 Get some trick flow heads and u will be well over your 300 hp goal. or just buy some NAWS- 250 shot ftw.
