Procharger or Kenne Bell?
#21
Novi-2000 are sick! MPH built a 2v with their custom cams, STOCK heads, and built bottom end with a intercooled novi-2000 and it pushed over 600rwhp! I forget how much pressure, I think it was 18 or 19 psi
#23
#27
You dont have boost with a centri until WOT either. The difference is the amount of boost between the two at WOT. A centri builds boost dependent on RPM, where as a KB will show pretty much full boost at any RPM both of which boost is only shown at WOT.
For example... Only an example dont judge lol
Procharger capable of 8lbs will be this way at WOT.
LBS OF BOOST 0 1.5 3 5 6 8
RPM 1000 2000 3000 4000 5000 6000
Kenne Bell
LBS OF BOOST 6 7 8 8 8 8
Kenne Bell
#28
Kenne Bell
Kenne Bell
#29
The 2000RR is just reverse rotation of the regular 2000 model so it can be mounted backwards like most 4.6L superchargers are mounted. Still a bad *** blower, but it's not the "racing model."
Dragonus18
09-09-2015 01:21 AM
