Who Installed Gears From AM....
#21
For me im talking about 50K+ miles. So w/ the FRPP (professionally installed) gears all I should buy is the install kit for $35.99? I wouldn't need anything else?
#22
Kit Includes:
- Pinion Seal
- Carrier Shims
- Crush Sleeve
- Pinion Nut
- Cover Gasket
- Ring Gear Bolts
- Brush
- Gear Marking Compound
- Loctite
#24
No, dont buy that kit..
The only thing you WILL need from that kit is the pinion seal and maybe the loctite. If you want to swap the ring pinion the fast and cheaper way, you replace just the pinion bearing and ring/pinion. The FRPP gears come with the shims, sleeve, nut. If you want to replace the bearings while you have the rear apart, then it'll cost you close to 125$ for the parts.
#25
The FRPP gears come with the shims, sleeve, nut. If you want to replace the bearings while you have the rear apart, then it'll cost you close to 125$ for the parts. 2 axle bearings, 2 carrier bearings w/ 2 races, 2 pinion bearings w/ 2 races, 2 axle seals, pinion seal, RTV for rear cover, 3 bottles of fluid + fricition modifier. etc.....
#26
Thanks everyone. i kinda get it....maybe the question has already been answered so i apologize if im still not quite understanding. Why would I want / need to spend an extra 125? Is it like an extra insurance policy? If so them im good with what i needed to know.
#27
Personally I think I've made up my mind to get the gear/tuner package, then purchase the $74.99 install kit (the one that comes with bearings) as well. I'm just not sure it I want to do the track-loc. Its hard to get straight what everyone used/didn't use. Seems like everyone has different ways they've installed there gears. Both ways seem to be going fine.
#29
#30
