lower intake manifold help pleaseeeee
ok so i just installed a set of comp cams stage 2 with the valve springs and cam gears, they told me changing the lower intake manifold would work great with the aplications i have, im looking at americanmuscle and they have acouple of diffrent ones Elderbroke Victor jr EFI, then they have the same 1 but carburated then they have professional products typhoon intake and last they have ford racing PI intake manifold?? i have no idea which to get but i want the best hp gain and most reliable one plz if anybody can give me advice and diffrences between them thanks alot
To be completely honest.... I'm not sure if you'll hit the power levels where any of those intakes would see any significant gains. There aren't a lot of great options for intake manifolds for the 4.6 to start with either.
with comps you dont need anything other than the stock pi manifold. You have to be spinning your motor upward of 6500ish to really see the benefits of an aftermarket intake. The stock pi manifold is really pretty good, its only downfall is its plastic.
f that...i replaced it with a good old metal one...i want to at least pretend it wont fall apart on me...Altho heat soak is more of a problem, only on warm/muggy track nights though. but yea dont replace it until you have to at least.
