Trying to get better 60ft times with 2v auto
#21
Back from the dead, sorry haven't posted in some time as you can tell mainly because I didn't have the internet and my comp had a virus. Well a little update from the last posts back in July I added UPR adj. sph. bushing u/l control arms, pulled my front sway bar off and on same street tires I was able to click a 13.5@101 with a still crappy 2.1 60ft. My goals still stands for a 12.99 pass on full bolt-ons minus cams with big & littles with M/T drag radials and 11.99 with 100-125 shot with full bolt-ons minus cams. I'm scheduled this Tuesday for my install of Strange 10 way adj.shocks/ struts, UPR full coilovers, and UPR k member @ STP (South Texas Performance) in San Antonio, Tx.
#24
i cut 1.7X 60 ft all day long. i have no suspension work as of now . my current setup is a 3200 stall and mt drag radials . i bring it up to about 1900 with 17-18 psi. and stay pretty consistent. it could just be you need to change your style at the line till you find what works best for you and car
#25
I pretty much have a race prepped rear suspension and on 17" wheels with M/T's I was also cutting 1.7x's. I just put rear coilovers in and have the front K member setup waiting to go in. I'll be gettin big N littles soon as well, I'm looking to be in the 1.5-1.6 range when it's dialed. I think you basically have my rear setup without the ARB, so you should be killing it this season.
#27
Not trying to threadjack but Im wondering what the ideal tire size is for the track because Im debating still (back and forth ALOT) about what direction I want to do for brakes. Either cobra brake kit (limited me to @ least 17in wheels) or keeping GT & adding slotted rotors (then I could run a smaller tire). Im not currently planning too my strip & my mustang is mainly a DD just looking into all avenues b4 I choose.
#30
Update: I got three passes on the new k member and full UPR coilover set-up with 15" m/t drags in rear no littles. I dead hooked leaving off idle smashing the gas on all three passes giving me consistant 13.2's and 1.8 60's with a best of 104mph. These tires are awesome and don't really know why I waited so long to buy them. My question is even though I knocked off 3 tenths in my quarter should I be cutting 1.7's or lower et's with my mods or they about right? I had my suspension set at second to loose in front and second to stiff in rear per UPR instructions and tires at 18 psi. I feel the tires did their job but was thinking with the weight reduction and "race suspension" I would shed a little better time.
13.0's-13.1's. Let me know what yall think.
