Is this a reasonable estimate for paint?!
Unless I am missing something, the scoop looks fine, it isn't a screw that holds them on, but retainers that slide into those slots, the three slots look to be in good order from what I can see. Also, with what jay-rod posted, in all caps i might add, don't forget that the paint is 2 stage base coat, clear coat, so if you use a spray can you only have one coat and run the risk of getting something that looks awful because of lack of skill, or from a poor quality paint. I have used the spray stuff on some model cars, and I don't always like it. With our paint we mix everything in house, as do a lot of shops in our area. With car repair, a lot of times, it is true, that you get what you pay for.
are they still usable? my other side scoop has all 6 holes but the smaller 3 slots are almost ripped off and just kinda hanging.
This is what it's supposed to look like, but the slots are pretty much broken though.
Wow you should look into things before torching them! My recomendation is a two stage basecoat, clearcoat. It is solvent based automotive paint, OP needs to buy primer, basecoat, and clearcoat. I have not painted anything finish grade before and I can get it right on small areas like a scoop. I am not saying paint your whole care with it as that should definately be done by a pro, but you can easily paint misc parts individually yourself, and have plenty of paint leftover to paint something else later.
And OP, sorry, I didn't see that other section missing, you may have to use double sided tape then.
mungodrums
09-28-2015 10:54 PM
