living proof, 78mm T/B is NOT too big for N/A :)
#22
so the really if the bbk 78mm t/b plenum kit is 269.99 and giving the same performance as your 70mm t/b and seperate plenum that was at least 400 for the two parts. . . . . . . . . . see where im going here. if you can get the same performace out of the 78mm for 35% less money. who's the smart one here ?
#23
That makes me feel good that you guys are getting the same power for the seperate throttle body and plenum then the 78mm throttle body plenum as thats what I have. I never had any issue with too tight of screws or stripping anything luckily!
#24
If you have a 18V or better screwdriver/drill with a torque clutch you can often use it as a sort of low torque impact wrench--just set the driver's torque to a high setting and let it bang away on the screw. I have found this works great on things like the TPS screws on our cars, and other absurdly tight Phillips and socket head machine screws.
#29
The only thing air related that will ever increase power is the weakest link in air flow. That's a fact. Kenne Bell doesn't even bother selling a TB or upper intake higher than 75MM even for a kit at 14 PSI for the 2V 4.6L New Edge. Something about the fact that a 75MM TB @ 14 PSI on a twin-screw supercharger will flow everything the engine can ask for tells me a 78MM is worthless both FI and N/A. But i'm crazy like that.
