Looking to get 18x9 in front 18x10 in the rear. What is the best tire sizes for the front and rear. Definitely want larger and wider tires in the rear. Thanks for the help. Jerry
Well, it depends what you do with the car. If you just want some cheapos to burn out with, get some sumitomos in the above listed sizes. If you like to stick to the road, these up front, and these or these out back...
I would recommend a set of 265/35's and 285~295/30's for such a set of wheels. Have you thought about what brand/make of tires you want to run?
Jazzer
I have 265/35 and 295/35 right now.. I like the look of the rears.. but the fronts could use a little more sidewall to even it all out. I didn't care for the look of the 295/30 though.
