quick oil gauge question
Hey a_penguin was telling me how to install my aftermarket oil gauge last night... I just had a real quick question for those of you with a mechanical one... do you have to bleed the actual line to the gauge itself? I was just thinking about that in bed for some reason lol. Anybody want to shed some light on that for me? thanks guys.
Over the years I have read installation instructions that said to do it, and those that never mentioned it.
That said I have never bled the line for a mechanical o/p gauge--my thought's being that the air will compress to whatever the oil pressure is and pass it on to the gauge--and the bit of dampening the air cushion provides (it would be "sponginess" in a braking system or clutch) is not a bad thing...
if that was the case and i dont think it is then the air would only "absorb" so much until it was totally compressed and your reading is correct( hope that makes sense) i know what im trying to say anyways ...lol. to date my pressure reads fine with out issue .
Did you use plumbers tape on the streads? Can I trust that hose to set in that gauge securly? I mean, it looks like you tighten it by literly placing that small metal piece over the hose (and tightening)
Hydrostatic load cells and "air over oil" indictors were very common in the pre-electronic era with the air column used to "snub" the gauge and keep it from jumping about. A rope mill I worked for had a test bed for testing rope (up to 1.5M lbs) that was built by the Baldwin Locomotive Works during WWII that used such an indicator.
In the early 80s I converted it to use an electronic strain gauge load cell system from a company named BLH electronics--which we found out during the process was Baldwin-Lima-Hamilton, the result of Baldwin Locomotive's having merged with Lima-Hamilton another locomotive works--they used it in some of their ads...
good luck with install
