what size fuel injectors do the 02 gt come with stock? I was thinking about 39lb or the 42lb injectors? will I gain any power from them if so about how much?-thanks-
If they are orange they are 19lb/H, if pink they are 21lb/H...
As to power gain, there will be none--even if you were to have the car tuned to properly run with the larger injectors.
If you don't get a tune the car will run like crap, and you will lose 150 to 200 HP--with the 42lb/H units, and no tune, you would probably lose the entire 260HP as the engine wouldn't even run...
