Trick Flow heads or Patriot Performance
Old 05-08-2010, 07:31 PM
jgpc1984
jgpc1984's Avatar
Default Trick Flow heads or Patriot Performance
hello to every ones here. im from venezuelan and i got a 2001 gt. im thinking to take in my stng a pair of trick flow new heads or patriot performance stage III, witch one its the best, and what cam its recommended, i was thinkin on :
stage 2 N/A cms :560/.575 lift, 225/235 .050" duration, 108 LSA
or
hitech stage 2 N/A: 234/230 duration, 111 lobe sep, .550/.500 lift
witch one its the best ,ore if there is another best in the market tell me please.
i use 125 hp spray.
im really ancious to reads yours answers to take my finally chose. thanks
and excuse my lenguage fails.
jgpc1984 is offline
Old 05-08-2010, 08:17 PM
0949er
0949er's Avatar
no complaints from my Comp Cams 270AH's, sound bad *** and you put VTs in my car you'll probably make the same numbers (give or take a few HP difference tops)
0949er is offline
Old 05-08-2010, 08:22 PM
Mustang_NTriangle
Mustang_NTriangle's Avatar
OP I have CMS 2.5 blower cams an love them but my lsa is 114 i believe. Jim is correct with similar cam characteristics his cams with lower lsa of 108 will outperform on with bigger lsa but as impacts the following is if a street car you want a larger power band range.
EFFECTS OF CHANGING LOBE SEPERATION ANGLE (LSA)
Tighten (smaller LSA number)---- Widen (larger LSA number)
Moves Torque to Lower RPM ---- Raise Torque to Higher RPM
Increases Maximum Torque ---- Reduces Maximum Torque
Narrow Power band --- -------- Broadens Power Band
Builds Higher Cylinder Pressure ---- Reduce Maximum Cylinder Pressure
Increase Chance of Engine Knock ----Decrease Chance of Engine Knock
Increase Cranking Compression ---- Decrease Cranking Compression
Increase Effective Compression ----Decrease Effective Compression
Idle Vacuum is Reduced ----------- Idle Vacuum is Increased
Idle Quality Suffers ----- -------- Idle Quality Improves
Open Valve-Overlap Increases ------ Open Valve-Overlap Decreases
Closed Valve-Overlap Increases ---- Closed Valve-Overlap Decreases
Natural EGR Effect Increases ------- Natural EGR Effect is Reduced
Decreases Piston-to-Valve Clearance ---- Increases Piston-to-Valve Clearance
Mustang_NTriangle is offline
Old 05-08-2010, 09:24 PM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
mrtstang...which cams did you go with? VT Stage 2 or Comp Stage 2? I mean those were the two that you narrowed down.
WannaBeGearHead is offline
Old 05-09-2010, 03:09 AM
97modifiedmustangGT
97modifiedmustangGT's Avatar
Originally Posted by Beamer03GT
No **** but I'm talking about for stock heads and not having to notch the pistons like most people do w/ stage II cams
name one person that HAD to notch their pistons with cms stage 2's. if you have no experience with these cams please don't speak like you do.
OP go with the cms cams. i think they will be great for what you are doing. i loved mine
97modifiedmustangGT is offline
Old 05-09-2010, 08:25 AM
lizzyfan
Underboss
lizzyfan's Avatar
He went with MHS
lizzyfan is offline
Old 05-09-2010, 08:28 AM
mrtstang
mrtstang's Avatar
Haha...hey i started out like everyone else. When i made that thread i had only just begun my research. I'm was very fortunate to have run into into guys like Nick and John Tymensky, as it totally opened my eyes.
mrtstang is offline
Old 05-09-2010, 08:30 AM
mrtstang
mrtstang's Avatar
Originally Posted by lizzyfan
He went with MHS
He knows that. He's just messing with me lol.
mrtstang is offline
Old 05-09-2010, 09:13 AM
kugzgt
kugzgt's Avatar
mmmmmm MHS = ****
kugzgt is offline
Old 05-09-2010, 09:17 AM
lizzyfan
Underboss
lizzyfan's Avatar
Woe is me, Mr Naive
lizzyfan is offline
Quick Reply: Trick Flow heads or Patriot Performance
