Need help with detonation stock 98 GT
Thanks Cliff I was afraid of that as that is a pretty big job and one I can afford to do. Is it possible its just my injectors? I think I can replace injectors a lot cheaper and do it myself.
Ok Cliff I will take it to the Mustang Shop here in Arizona they know what they are doing and seem honest.
Hey one last question....
Do you have any alternate suggestions on alternate terminations (I know its not EPA approved and only for "racing") on the two lines going to the air intake one being the crank case exhaust the other is not sure it comes from the throttle body. I ask because I am having some routing issues with my new manifold and have to rework a bit and it I can:
A. Put a breather on the crank case (I assume it needs to breath?) without causing a tuning issue that would be great.
B. Plug the hose connection from the center of the throttle body to the air intake?
Not being concerned about EPA stuff more concerned about if these lines are some how metered or needed to be hooked up for performance.
Thanks for all your inputs on helping Cliff!
Thanks Cliff I was reading a bunch of threads on the crank case breather options and dilemmas. I think I will keep it stock and use fresh hoses and claps to make sure I have no vacuum leaks. I think it is the PCV line(s) even though it does not come from the manifold itself but does come from the center of the main throttle body (its a 3/4 hose) it runs to the air intake and has some square inline filter?
mungodrums
09-29-2015 09:18 PM
mungodrums
Suspension
09-24-2015 10:12 PM
ccdguy
09-19-2015 05:20 PM
