Lowered 03 GT Suspension Question
I am a new member and have a question about the rear suspension on my 03 gt. I recently bought my stang and my axle dampers are acting up and making a clunk/knocking noise anytime the suspension would move. I want to eliminate these by possibly changing out my rear lower control arms, im having trouble picking a good set out for my application.
The springs i have are cut and i want to replace them with actual lowering springs. I have these 2" lowering springs in the garage and am ready to install them.. http://www.ilovebodykits.com/product...s_LSFD01_.html
I also have steeda adjustable tie rod ends and polyurethane spring isolators for the rear because the rubber ones are worn out. Can someone guide me to what lower rear control arms would best fit my application for my lowered car and does anyone know if the control arms will eliminate the stock axle dampers?
thanks in advance
steve
By kmastl
thanks in advance
steve
By kmastl
http://www.americanmuscle.com/maximu...rms-99-04.html
thats what you want and then you can pull off the quad shocks.
09-08-2015 11:50 AM
