T-45 11'' Clutch?
T-45 11'' Clutch?
So I'm changing the clutch in the Mustang the past few days, but it has been nothing but a headache. Not because the install is going horrible, it's because all the parts seem to be wrong.
I check my VIN code and see that the 8th character is a X. That means I have an 8 bolt crankshaft, right? Wrong. It's a 6 bolt. I find that out after the transmission is already out and I have an 8 bolt flywheel waiting to go in. I don't know where I heard that, but I shouldn't have believed it!
I check the TR code on the door and it's a 6. That means I have a T-45. I didn't know Tremec made T-45's... So maybe I have a TR-3650?
I ordered a clutch to work with the T-45 up to the Mid 01 GT's (10.5''); that doesn't work because the flywheel is clearly an 11'' flywheel. So now I have a clutch and flywheel that's useless because I don't know how to read.
Has this happened to anybody else?
Man I wish there was some way to clear this up. I definitely have an 11'' clutch. And my transmission is a Tremec. The transmission code in the door says it's a T-45. Is there anyway to identify the transmission by the code on the side of the it?
Tremec acquired the Borg-Warner tooling and license for the T-45 in late 1998, your 2001 could have a Tremec T-45 as the changeover to the 3650 was made in the mid-2001 MY.
The 8th digit of the VIN indicates the engine displacement and number of cylinders, "X" = 4.6L V8 SOHC. Transmission code 6 on the data plate indicates a T-45 transmission.
I believe that all of the '99 through '04 GT's used 11" clutches--could be wrong here though...
