Need help with 24 lb fuel injectors
On a 98 mustang GT i just put 24 lb injectors and the guy is in a super hurry to drive the car for a wedding Saturday. Can he drive it on the stock fuel pump? If i have to install the bbk 255 lph that he has should i replace the stock regulator. The car also has the BBK 24 lb mass air flow and BBK 78mm Throttle Intake and BBK cold air intake. Thanks for any help.
Is the car stock other than things listed? If so the computer will only demand as much fuel as the stock motor needs. I believe the later PI engines came with larger injectors stock. Unless Turbo/Super/Nitrous the computer will correct the A/F ratio for that injector and matched Mass Air meter.
Thanks for all the replies. I will pass the BBK info onto him. The engine is stock but he has a lot of future plans. Now does anyone want to put these BBK long tube headers on for me, so far a PITA.
thanks for any and all help!!!
