MM Clutch Pedal Height Adjuster, 1994-04
I purchased the Maximum Motorsports Clutch Pedal Height Adjuster, 1994-04. All I can say is WOW!!! It took maybe 30 minutes to install, The MM instructions are great, wouldn't expect anything less from MM. I did it without pulling the seat, which was a little bit of a pain but saved a little time I think. The clutch pedal is now even with my brake pedal. It keeps my knees off the bottom of the steering wheel and and makes the clutch a ton easier to engage/disengage, it has a much shorter travel now. It only cost $19.95, but you do need a clutch firewall adjuster and aluminum quadrant. I highly suggest the MM ones as they are top quality, easy to install and nearly bulletproof. Here is a link to the Clutch Pedal Height Adjuster, http://www.maximummotorsports.com/st...roducts_id=502.
Here are the before and afters, you cant tell too much from the photos but i can tell you it made a huge difference, i recommend it to anyone the wants shorter clutch travel or constantly bumps knees on the steering wheel when doing your footwork.
Before:
After:
Before:
After:
Clutch Cable Firewall Adjuster, 1982-2004
http://www.maximummotorsports.com/st...roducts_id=500
Aluminum Clutch Quadrant, 1982-04
http://www.maximummotorsports.com/st...roducts_id=503
junior04
09-28-2015 10:53 AM
