oil pan change
oil pan change question please help
punched a hole in my 7 quart, need to remove it to fix it, i know you can drop k member, sounds to me to not be that hard, is it just me or is it only like 4 k member bolts, and 2 engine mount bolts, to drop it enough to get the pan out? anyone have pictures, or tell me if that accurate or whats involved.?
The K member is 8 bolts, 2 inside each wheel well, and 2 in the back of the k member on each side almsot where ur subframe is by the pinch welds. Unless you completly remove the k member you're going to have to drop the pan low enough to get in there and unbolt the oil pick up tube to slide the pan out it can be a PITA.
