Transmission Fluid
Old 07-14-2010, 05:35 PM
.boB
.boB's Avatar
Since new, I'v been using GM Synchromesh in my TKO - as Tremec recommends. The TKO tends to be a bit notchy.
This time, I decided to use Royal Purple auto trans fluid. I didn't expect to notice any improvement, but the RP was a little bit cheaper. Since I uses RP in the diff and crank case, I figured it wouldn't.
Surprisingly, I did notice an improvement! Shifting seems to be a little smoother, especially 2-3. I often slip it from in to neutral without releasing the clutch. 3rd and 4th need a little extra effort. Even that improved.
As I said, I was surprised, as I didn't expect to see any change. I can't wait to get back to the track and see how it does.
.boB is offline
jwog666
12-27-2021 08:09 PM
Thunderball
15
11-22-2015 11:49 PM
wraith777
09-28-2015 10:49 AM
09-25-2015 06:42 PM
Quick Reply: Transmission Fluid
