Thought i'd seek help from the wizards on Mustang Forums (with video)
Alright, please read carefully:
Bought 9007 HID kit from DDMTuning, 8000k 55W
Installed kit with the car off, passenger side bulb would go on for a split second, then turn off.
I turned the car on, same situation.
I turned the car off left for a little while, then when I came back, RANDOMLY, BOTH lights went on and stayed on.
So today, I drove to work, fired up the HIDs, and they both went on fine.
8 hours later, I go to my car, turn it on, and the passenger side bulb flickers once, then stays off, AGAIN.
Determined to fix this problem, I call DDMTuning. They tell me to switch the ballasts and bulbs from side to side (put all the stuff on the left on the right and swap around everything.
So, whatever, I do it. I put all the main wiring over on the passenger side this time, and swap the bulbs AND the ballasts.
I turn on the lights and woohoo they work!!
Then, 5 minutes later... I turn on my car, and now the DRIVER'S side is out.........
http://www.youtube.com/watch?v=76vONkxFQpk
Keep in mind, it is PLUGGED in, when the light goes out. I left the connection in. It just flickers, then turns off immediately.
Is maybe the connector that I plug into the ballast bad??
I did!! lol And I left it plugged in too!! Multiple times. I know I didn't plug it in so it snaps in that video... but even if I did plug it in fully, the light would just flicker and go out. I was just making connection, then taking it out once the light went out, making connection, then taking it out once the light went out
Any other guesses? I'm going to call DDMTuning today and tell them what's going on.
Everyone thinks it's the ballast? Or the connector?
By the way for the record... car was on, AND car was in ignition last night and guess what!! BOTH lights worked.
Now, this morning, after the car sat in the garage all night, the driver's side bulb is OUT.
just my .02
^What he said. And my suggestion is that you return the kit in it's entirety, exchange for another new one. If I get brand new crap that doesn't work correctly and I'm confident that I've installed or attempted to operate correctly, it goes back. You've been screwing with this thing for days, dude; send it back.
the connection is bad. either the wire to the clip, or the wires inside the ballice, one of those connecotrs has a bad connection. that would be why it works some times and why it doesnt. Plug it in and jiggle the wire coming off the ballice I bet you the bulb flickers or does something.
