okay so i just checked and it was blown lol i changed it and the light was still on so i had my friend clear it with his scanner and he saidto wait to see if it comes back on is this normal?
Is the car running without blowing the fuse right away?
Do you have long tube headers? Could have melted the insulation on the O2 sensor wires. Disconnect the TPS and measure the resistance between the Green/Red wire and ground. If the resistance is low, this indicates a short in in the wiring somewhere.
so i am having the same problems with a low idle at stops and it even sometimes dies. could it all be because of that fuse or is that a whole different issue?
Your issue, if you are not throwing codes, is more than likely the IAC, as described at the beginning of this thread.
Originally Posted by agarr19
ive had longtube headers for about a year and idk i havent checked the fuse again but the car was fine for about a year
So is the car running fine now? No CEL's? Just for piece of mind, I would crawl under there and take a peek at the O2 sensor wiring to make sure you don't have anything melting or damaged in any way.
