mach 1 hood mounting question.
ok so i have a 2000 gt. and iv looked into putting an 03-04 era mach 1 shaker hood and shaker kit on it. my question is will it mount up and do i need something special for the shaker kit since the mach 1 hood is taller then my stock GT hood. Thanks.
true i have a cdc shaker kit and th plastic part that goes on th hood flew off at 130+mph when i was in germany so i ended up getting an aftermarket mach1 hood from carpartswholesale for like $300 or smthn cant remember the exact price but that hood has a high bulge like the mach1 hood so it should work bc i have the cdc shaker and put spacers under the bracket to bring it up a bit to flow right with th look of the hood. not sure if they still sell th hood though.
i did this a while back to my gt.
you're gonna need the big black bracket that holds the shaker to the engine.
i had to make two front brackets to hold the front of the big black bracket.
then i made a bracket for the back. it's pretty simple. these pics are similar to what i did. hope these help
i used the 2 bolts where the throttle cable is attached to the plenum to attach the back bracket.
i think the spacers that i used ontop of the alternator were only like 1" tall instead of 2" like pictured.
jwog666
12-27-2021 08:09 PM
breaking
10-02-2015 01:27 PM
