S/C Build Complete..
#41
^^^^38 more days brother...I had planned on having a buddy of mine take to the shop last week but decided to put it off until the 10th... I'll keep you guys posted..
#42
what kind of boost does a kit like that put out? real question is is it a must for an intercooler on that kit "t-trim" bc as of right now i have a v1 s-trim said to put out 7-9lbs with the stock pulley and vortech support rep said i wouldnt need an intercooler with my kit. so b4 i try to do an install im just debating on should i just get an intercooler with the bov or should i just buy a bypass valve and get the kit bolted on bc it didnt come with a bypass valve
#43
T-Trim and S-Trims have the same step up ratio so they turn the same boost relatively. T Trim is simply better because you can spin it faster. He is going to be pushing around 8psi with his setup. Going with an intercooler is not a must, however it does keep intake temps down which lowers your chance for detonation and allows you to run more timing.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
