View Poll Results: Help me pick out my next mod for the car.
Mach 1 seats
11.76%
Corbeau A4
5.88%
Corbeau CR1
23.53%
Corbeau TRS
11.76%
Sony XAV-60 Stereo
41.18%
Other suggestions?
5.88%
Voters: 17. You may not vote on this poll
Poll for next Mod (Seats?Stereo?)
stereo seems to be a big hit!
only downside i could see is the wiring it up to my stock system (mach 1000) i heard there is a harness now days that makes it pretty simple. that and how it looks inside.
it cant look worse that that outdated headunit though.
^ Yeah, they have harnesses (you'l need 2 different ones) that will make the install pretty much plug n' play. And if you're running XM Satellite using the unit's transmitter, Best Buy has a thing called FM Direct (that's actually the name for the Sirius one, but I'm sure there's an XM equivalent) that plugs in inline with your antenna wire and will give you a clean signal, costs $30. If you end up getting a new head unit then just plug it in through the aux rca jacks. And while you're at it switch to Sirius anyway, they have better music stations imo (with the exception that XM is supposed to have a pretty good punk channel if that's your thing).
3g. In my area (burbs of Philly), I get very good coverage. I can stream pandora without interruption from my house to the Jersey shore (and back), so it's basically like satellite radio.
GT350 S550 Tech
09-29-2015 03:29 PM
