school me on o/r h/x
i currently have flowmaster american catback exhaust with magnaflow catted x-pipe. i would like it to be louder i was to go with an off road x/h
im just wondering will and o/r x/h bolt right up in replace for my current x?
also whats the deal with the oxygen sensors??
can i just cut em out and have pipe added?
lookign for a cheap o/r pipe and let me know everything i need and what to do
You can probably just tune it in, but with the MILs I know you will be able to pass inspection, whereas just fixing it via Sniper you would still fail, I believe. I've never worked with a Sniper tuner, so anyone correct me if I'm wrong.
mil's are no different than turning off the rear 02's witha tuner. if you don't have a visual or sniffer test, then the shop will just hook your car to an obdII reader and see if your throwing codes for no cats. no codes = your good.
your handheld should be fine to disable the rear 02's.
