Just about ready to install....
if your interested i have 39lb injectors and an extra pump that came with my kit, make me a reasonable offer.I would def get an intercooler because your not going to be happy without it if you plan on going to the track, and i would try to get a different oil feed hose because i tried 2 of them and they both leaked,and heard from alot of other people that they had them leak to, i had my friend make one from his work and worked perfect.I dint see it in the pic but did you get an IAT sensor relocator,it looks like your staying with stock maf but more than likely your gonna have to change that and with that you will need to relocate the IAT sensor
I forgot to put the Maf in the picture. I have a 90mm MAF. I do not have an IAT relocator though... Didn't know I needed one. Will look into that now though.
And I'll start looking into intercoolers... Is there a write-up somewhere on how to install those or is it fairly simple?
^ yeah, i kind of changed my plans. i decided i really wanted to get it installed and tuned before winter - that way i might get to drive it a time or two this year with the centri on it. and then i can do other projects on the car this winter. i can take longer on those since i wont be driving it in the winter.
intercooler is easy to install, the hardest part is fitting the pipes together because sometimes you need to cut parts of the inner wheelwell to get the pipe to come back up, theres one thread on here that has a couple pictures to give you an idea, if you have a lightning maf then you should need an sensor reloctor,i am not totally sure because i forgot what year they switched over to haveing it in the maf,you might allready have a separate one
Trust me you'll be glad you did
