Which hand held tuner is best ?
Contact Jon Lund, have him write you a tune after you send him some data logged files. It will be more than likely the best tune you will get remotely.
Otherwise, skip those n get a Delta Force Special forces package..
explosive - my shift points are fine. At WOT it shifts at about 5500 I think into 2nd and 3rd. Not sure Ive taken 3rd into that range yet. when not flooring it the shifts are lower, however, they are much firmer than stock, and you will be able to tell.
J-MOD your 4R70W man and it will snap your neck. Make sure to remove the bottom spring in the 1-2 and 2-3 accumulator. Bet it will be really sick on the Vortech.
Matt's 95 Stang
10-05-2015 07:16 AM
