Oil drain lines vs self contained
Old 09-04-2010, 06:25 AM
silverbullit02
silverbullit02's Avatar
Default Oil drain lines vs self contained
Ya I know another supercharger ? but I've searched and can't find any answers. Do people like oil lines that tap into the oil pan or self contained units?
silverbullit02 is offline
Old 09-04-2010, 06:32 AM
oxfordgt
oxfordgt's Avatar
I would much rather have a supercharger that is oil fed rather then one that is self contained. Most people don't want to tap the pan but only because they probably never done it. It take all of 5 min to tap the pan and I have never had one leak.
oxfordgt is offline
Old 09-04-2010, 07:37 AM
Mustang_NTriangle
Mustang_NTriangle's Avatar
i agree i would rather have oil feed once pan is tapped correctly much easier to maintain.
Mustang_NTriangle is offline
Old 09-05-2010, 09:12 AM
99GTvert
is my username.
99GTvert's Avatar
With an oil feed line, does the engine need a lot more oil added to it?
99GTvert is offline
Old 09-05-2010, 09:22 AM
bopiela
bopiela's Avatar
Not according to the Vortech install manual, seeing as I still only added 5 quarts of oil on my recently finished install.
bopiela is offline
Old 09-05-2010, 10:32 AM
Rockwell28
Rockwell28's Avatar
I would think that the one that taps the pan and uses the engine oil woukld be better than the self contained one IMO. I just thing the head unit will run a lil bit cooler than the self contained unit bc the self contained unit just uses the oil thats right there in the head unit the whole time and that has to get a bit hot after a bit of use. but the other uses oil that is in the pan thats been cycling through the engine or whatever so it May be a bit cooler than the self contained. And the oil always gets changed when you change the oil on your car goes through the filter and all vs self contained.
Rockwell28 is offline
Old 09-05-2010, 12:00 PM
0949er
0949er's Avatar
once you get over the initial "tap" there are no more headaches. I like knowing that if my car has oil... my blower has oil.
Self contained is just ANOTHER thing to check every so often... lol
0949er is offline
Old 09-05-2010, 12:39 PM
MustangMan00
MustangMan00's Avatar
tapping is NOTHING....everyone thinks its a big deal, as well as me before i did it, but its cake.
It doesnt take more oil, cuz all it does is spray up into the unit and then drain so theres really no more storage factored in
MustangMan00 is offline
Old 09-05-2010, 01:26 PM
oxfordgt
oxfordgt's Avatar
When I helped my roommate install his hellion TT kit on his cobra he was scared to tap the pan. I told him I would do it if he ran in the house and got me a beer. he decided to take a **** then get my beer and by the time he got back I was already done.
Moral of the story I'd much rather take a couple of min to tap the pan then have to buy expensive oil to change out the self contained one all the time.
oxfordgt is offline
Old 09-05-2010, 01:45 PM
Explosive
Moderator
Explosive's Avatar
I don't think people fear tapping the pan because of leaks ect. It's the matter of chips getting into the pan from making the hole. And making threads.
Explosive is offline
Quick Reply: Oil drain lines vs self contained
