Tire Hitting Fender Lip
#22
It takes some time to set the angle correctly. It also takes some strength as youre going against the differential as well. Other then that it was rvery easy to use. Everything you need comes with it. I would suggest using a cresent wrench to tighten up the angle part instead of the little handle though. and take your time! i got 1 little crack on the inside of the fender. Make sure you heat it up every couple minutes.
jwog666
12-27-2021 08:09 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
mungodrums
Suspension
09-24-2015 10:12 PM
