Breather caps on valve covers?
As I said above, in a properly operating PCV system there's nothing to "catch", however if you want to have a "catch can" for visual effect go for it...
The filter would prevent the water and oil from running through the intake and onto the valves and keep the intake and such cleaner no? Not going against what you said, just trying ot better understand how it works because this was more my understanding of it
Also how would it filter out any oil mist and boiled out water and such, isn't it just an open tube that feeds into the engine to burn such things?
On a forced induction or very high compression engine, with the higher blow-by created by much higher combustion chamber pressures, a catch can may be desirable to capture the this greater flow of crud from the crankcase.
However on an n/a DD disabling the PCV system and installing a catch-can is not needed, and I would argue detrimental to engine life.
Placing one in the PCV line won't do any harm, however the only thing it will collect is stuff condensed from crankcase gases, because of the heat sink presented by the catch can's existence.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
