Pulling out the Tranny.
Old 10-09-2010, 03:59 PM
Bmitchell373
Bmitchell373's Avatar
Default Pulling out the Tranny.
I looked, and it sounds like i can pull the transmission out without dropping the motor. I read you need to support the motor, but how much will it move if i just leave it mounted in there? I just want to make sure it can be done without a excessive amount of hassle.
Bmitchell373 is offline
Old 10-09-2010, 04:18 PM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
Just drop the exhaust and unbolt your transmission. The motor will be sitting in the motor mounts and the K member will be bolted up so no need to worry about the motor when pulling the trans.
Pretty simple to do.
WannaBeGearHead is offline
Old 10-09-2010, 05:11 PM
98redstang
98redstang's Avatar
+1 ive done it like 8 times already with the stupid lts. What a b!tch! hahah With just the stock exhaust you'll be fine though.
98redstang is offline
Old 10-10-2010, 04:47 AM
SilvrStang
SilvrStang's Avatar
Agreed on both posts above. Disconnect the starter and the harness unbolt the sucker and drop it. If you have anyone that has a motorcycle jack it makes life 500 times easier.
SilvrStang is offline
Old 10-10-2010, 12:10 PM
Bmitchell373
Thanks guys. I'm hopping there will be a tranny jack there.
Old 10-10-2010, 01:39 PM
98redstang
98redstang's Avatar
+1 used the jack for the harley haha. Of course after i got it down i didnt have the car high enough so i had to knock it off the jack to drag it out haha.
Old 10-11-2010, 03:23 AM
SilvrStang
SilvrStang's Avatar
Yeah man isnt it always a bitch wn you think you got the car high enuff then it fails lol
Old 10-11-2010, 05:58 AM
uberstang1
Chupacabra
uberstang1's Avatar
God bless you..... My route is to drop the driveshaft,powersteering pump,heatercore and rad hoses, then unbolt the k member and tranny cross member and drop the whole mother out. Then remove the bumper cover and use a hoist attached to the bumper and pull the whole car high enough to slide the drivetrain out.
uberstang1 is offline
Old 10-11-2010, 07:43 AM
Bmitchell373
I thought about dropping it all, but i know id wana tear into the motor. Cant afford that yet.
Old 10-11-2010, 08:04 AM
PurpleIcedGT
PurpleIcedGT's Avatar
Taking the tranny out wasn't to to bad...I just did it last month. With a lift and a tranny jack, the worst part was reaching the last bolt on the starter.
PurpleIcedGT is offline
Quick Reply: Pulling out the Tranny.
