Mustang GT is giving me problems!
I checked all vaccum hoses for leaks, cleaned my maf sensor, cleaned my iac, and even the throttle body while I had it apart. Spark plugs are all new, so that's not the issue. Still experiencing the problem. Today I discovered the 2 front motor mounts are broken as well. I'm not sure if this would cause an idle issue? I would assume so, being that with the motor mounts broken, everything would be knocked a bit out of whack.
See I ran a diagnostics on my car a minute ago because the check engine just came on and it said something about mass air malfunction. It's got the factory pipe from the throttle body to the air filter which is just a simple K&N intake. What do I need to do to take care of this?
If the TPS sensor is bad the idle will hang drastically usually and surge at idle, to check for a faulty TPS simply dissconnect the connection to it and see if the idle changes and remains normal, if so the TPS is bad.
NorthAmericanTuning
03-18-2016 11:21 AM
08-10-2015 02:02 PM
