Now I have the freedom but what to do?
Ok here is whats going on right now. I just got the wife a new ride (keeping her old one for my DD) and since I'm doing that she said I can do whatever I want to my car! (mistake on her part but shh I wont tell if you don't)
Anyways I was wanting to push around 550hp. Now I know the stock bottom end wont hold that kind of power so should I just buy a short block or buy a bottom end and use my block? (Was reading some where the stock block was good for around 1000hp?) If you all say I should get a new short block what do you think about maybe dropping a 331 stroker in there? Or what about maybe a 5.4 since I wouldnt have to change any of the wiring? Price isnt anything I'm worried about. I'm going to take my time on the car.
Easier and cheaper to just buy an mmr block unless ur doing all labor rebuilding ur lower. I wouldn't bother with a stroker or 5.4 ur HP goals are very easy to get with a 4.6 its added cost to go fancy for no real reason except "cool factor".
Ok thanks for Suggestiong MMR hadnt looked at em before but the look to be pretty solid. Is anyone using MMR short blocks right now and if you are how did they treat you? Everything been pretty solid since?
Definitely prioritize budget/goals/etc.
If you want 550rwhp (which is what my current goal is) I'd go with something like this...
MMR 900 Built Short Block
MHS Stage 3 Ported PI heads
CMS Stage 3 Blower Cams
Kenne Bell 2.6Blowzilla
The Fuel System to support it & a great tune
Suspension wise -
These other guys can help you w/ that more in depth but I'd go with coilovers, tubular K member, 31spline axles, cut stock rear springs, Bilstein struts...
Then I'd make sure I had one hell of a good tire setup so I could have some fun w/ it!!!!!!
Suspension wise -
Suspension wise -
Suspension wise -
I've not really looked at the MHS heads but I have been looking at trickflow twisted wedge. I've had trickflow products in the back and I've not had any problems with em in the past.
I've noticed on this board everyone always talks about cutting there stock springs. Is there a reason why cut stock springs are better then after market or just cheaper?
Suspension wise -
Suspension wise -
and to ^, its free to cut your springs vers buying springs just to do the same job of cutting your stockers. thats why people do it.
Anyone use the trickflow heads? Heard anything about em? I had the twisted wedge heads for a 306 a few years back and loved em. Just wondering if they were as good for the 4.6 as they was for the 5.0
they are the best bar none. but to take REAL advantage of them you need some very aggressive cams and be revving to the moon. if you aren't doing that, theres no point in spending the extra $, you will see just as good of results with some ported PI heads.
