What is your 60 foot with 555R's
#21
Any control arm that is basicly the same design and mounts in the same place as the stock ones are worthless. megabite, comp engineering, or liftbars that relocate the the axle mounting point of the lower control arms are the only ones worth anything. Baseline suspension is the only company I know of that makes good uppers that relocate the mounting points. All the others like, steeda, mac, summit, and maximum motorsports are really only good for street driving and not for drag racing.
I'd go to baselinesuspensions.com and read some of the tech info on there about how to properly set up your suspension. Pay close attention to the "Instant Center" stuff. That is one of the main things wrong with the stock 4-link and what the contrl arms we are talking about try to correct.
#23
I am usually around 1.88-1.92 with 315 05R's bone stock suspension(actually eibach lowered) dumping it from 3K. But that is changing this weekend with UPR UCA's, UPR LCA's, and Strange 10 ways all the way around.
#24
What suspension mods were in place when the 1.4 60' occurred on the Nitto R's???
I'm not saying it didn't happen, but that is a SUPER low 60', especially for a DR !!! I'm curious how you managed to pull that off.
#27
I have cut a few 1.82x's with mine. This was on a warm day though.....one of those passes I dropped the clutch from damn near 6k and it just hooked. That's not the norm, though, so I don't mean to say they are like slicks but WOW. That day was something else.
I have bolt on power with 4.10s and HPM LCA's with strange shocks/struts. I have also cut a few more in the 1.8x range.
#28
In the rear was megabite jr. lowers set at 100% anti squat, Baseline suspension pro uppers, Baseline suspension anit-roll bar, QA1 coil overs, CHE axle brace and CHE shock tower brace. Up front was QA1 coilover and K member/A arms. The tire pressure was 18psi. Launched at 5000 rpms and making about 5 lbs of boost.
#29
running ~20 PSI I could not do better then a 2.16... my other two launches were 2.3's.
I did not heat them up much (burnout through water box for about 5 seconds TOPS), and my launch control is horrible and erratic (I don't do the same thing twice lol)
#30
Skip the water and you will do alot better. The water is for slicks.
